Boost Troubleshooting - with numbers - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-25-2013, 04:17 PM Thread Starter
Quoted: 2 Post(s)
OK - so I am doing some troubleshooting prior to getting any PHP or other tunes to make sure my *mostly* stock truck is working properly before I spend money on tunes.
So - I am down to finding out if my turbo is decent or not - I have a HYPERTECH programmer 3 on my truck - and even with that I was only seeing 17 lbs WOT.
I unplugged the red line to the waste-gate controller. With that off, I can get up to 21+ lbs of boost WOT (I had to back off as I ran out of road) - I assume it would go a bit higher.
Now, I know this is up for debate, but what are these numbers telling me? (Other than the HYPERTECH is a POS and I need to put it back to stock, spend some cash on some real tunes - and go from there)?
Is my waste gate controller bad? Something else?
Should my numbers be higher with the line disconnected? I don't see/feel any leaks, but I suppose there could be some. I was mostly checking waste gate control functions with this test - my issue is, I am not sure what the results are telling me.
Opinions? Thoughts?
01 F350 Dually 4x2 Long 7.3 - Manual - Mods: Hutch, Harpoon, Remote Fuel Filter, Southbend Clutch, Heim Joint, Gauges, Disabler, 08 Tail w/Camera, Pioneer Head w/Lockpick, Exhaust Brake, Rails, Air Raid, 06 Headlights, 50 cent. Coming next: Exhaust. Wish list: Train horn, 4x4 conversion, Exhaust, Turbo, Chip.
06 Mustang GT - GCC spec (Infidels May be closer than they appear)
16 Sonata Hybrid - Gas saver
Arizona_SVO is offline
post #2 of 7 Old 03-27-2013, 04:24 AM
Jrz13's Avatar
Well 17lbs of boost is about what these trucks put out stock. The stock turbo maxes out at about 30lbs. Personally I don't recommend having your waste-gate unplugged but that's just me. I have never used a Hypertech myself but my TS chip with canned tunes pulled about 25psi on stock injectors. If you think your loosing boost, check your intake boots and up pipes.
Forged Rods
ARP Head & Main Studs
Port, Polish, 3 way valve job
Beans 160cc Single Shot Injectors
DI Regulated Return/Oil X Over
DieselSite Coolant Filter
TS 6 position (Beans Tunes)
AFE stage 2 dry
Labonte Stage 3 Methanol Injection
Banks wheels, exhaust housing, wastegate, Intercooler
5in Turbo back Exhaust
Custom Built Trans w/ Billet Shafts
Mag-Hytec Trans Pan/Diff Covers
6.0 Trans Cooler
SnowDogg EX90 plow
Jrz13 is offline
post #3 of 7 Old 03-27-2013, 08:37 AM Thread Starter
Quoted: 2 Post(s)
Thanks for that info about what the truck produces stock - I have tried searching here for that, but some folks say it goes much higher than that which is why I was looking to see if I had an issue in the first place.
I am now confidant that I do *not* have an issue - and can now proceed to get to tings like tunes and other mods. Just needed to establish a baseline.
Thanks!
post #4 of 7 Old 03-27-2013, 02:36 PM
I have a mostly stock 01 with little mods like a 6637 and whatnot, and I can pull about 20 psi of boost with my Edge tuner. My exhaust manifolds, and up pipes leak profusly. Stock "OK" spec is 16 PSI. I would pressurize your intake system and check for leaks, other than that, you should be good to go!!!
Have fun!
-Nate
'01 7.3L PSD SCLB
Rubber:Ballistic Jester 18x9, 325/65/18 Falken Wildpeak A/T's << LOVE THEM!!
Motor:CCV mod, Zoodad mod, Edge Evolution CTS, Coolant Filter, Cat ELC, Dual Optima Yellowtop Batteries, 6697 mod
Suspension: Polyurethane sway bar link kit, 6" lift
Naterenfo1 is offline
post #5 of 7 Old 03-27-2013, 02:41 PM
blue99stroker's Avatar
Quoted: 283 Post(s)
i would check your up-pipes and make sure they aren't leaking that's a common problem.
look at the firewall and see if you see any soot, you can look from underneath too.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #6 of 7 Old 03-28-2013, 06:15 AM Thread Starter
Quoted: 2 Post(s)
Thanks all - I don't think I am leaking, but I figure when I do the mods I am planning, I will probably swap out the hoses/connections anyway just to be sure.
In the meantime - time to crawl under and look for soot.
Thanks!
post #7 of 7 Old 03-28-2013, 08:49 AM
TSbeanspowerstroke's Avatar
before i had the chip and boost fooler everything else stock with 6637 intake and 4" exhaust would hit 21 all day, red line to wastegate plugged in.
2000 Ford F250 7.3 4x4 158k miles. MODS: Beans Tunes, 4" exhaust, custom twin intake, boost fooler, ported housing w/ Clays 11 blade billet compressor wheel, foil delete, glowshifts 3 in 1 gauge, AIH delete, bellowed uppies
Future mods: banks intercooler, coolingmist, 6.0 trans cooler, BWD blue powder coated valve covers, BWD coated exhaust manifolds.
TSbeanspowerstroke is offline
