I need help - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-25-2013, 04:32 PM Thread Starter
I need help
I need help I am not sure what it going on I have had my 2001 F-350 for a year now I put on a 4" turbo back this weekend and am getting this wired noise when I put it in drive or reverse it is like a vibration slash rubbing or grinding noise that goes away as soon as I start to accelerate I have been looking all around under the hood and the truck I double checked the exhaust jacks up the driver side front end Fu#@ed with the 4x4 looked at my brakes hell I have even looked at the rock guard on the front of the truck everything is tight and seems to be in place I don't wana be one of those guys that blames the dealer but it happened the day after my oil change was done I know I have to be over looking something but I don't know I have been looking on the web for the last few days I am sure I sound like a total newbie but I wouldn't ask if I couldn't figure it out... thanks for any ideas
Coke220 is offline
post #2 of 9 Old 03-25-2013, 04:57 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Sure it's not the exhaust rattling?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 9 Old 03-25-2013, 05:12 PM
gotsboost's Avatar
I need help
Yup .. Sounds like it might be hitting the side of the cross member under the cab ... I changed the Vband on mine and had the same thing. Sounds bad under idle but starts to go away when I took off
gotsboost is offline
post #4 of 9 Old 03-25-2013, 05:19 PM Thread Starter
i will look at agen but from what i could see there was nothing hitting and every thing was tight and by the way whats the vband?
thanks
Coke220 is offline
post #5 of 9 Old 03-26-2013, 09:02 AM
gotsboost's Avatar
The clamp that holds the down pipe to the turbo
post #6 of 9 Old 03-26-2013, 03:01 PM
Mine hits the rear shock. Might be something to check.
99' Powerstroke is offline
post #7 of 9 Old 03-28-2013, 10:29 PM Thread Starter
so yea i looked at it and the v band and the cross member were the problem i thank you for your help i got it all taken care of. thank agen for the insight
Coke220 is offline
post #8 of 9 Old 03-29-2013, 09:46 AM
timmyboy76's Avatar
glad you found it My buddys' exhaust (downpipe) was hit'n the GROUND bolt on backside of motor. Laying right up on it. Removed it and relocated the ground strap to topside of motor. No more noise.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #9 of 9 Old 04-09-2013, 05:50 PM
gotsboost's Avatar
I'm glad u found the problem
I know things like this can be aggravating. lol
