KILLER COLD II......
I'm back with a lot of the same problems. I posted a thread the other day about -34 degree weather in Maine that reeked havoc on my commute to work. It was -35 last night and the same thing happened. I had it plugged in and it started fine. I let it warm up for about 20-25 minutes. I started of to work and it was fine for about 1/4 mile then all of a sudden it loses power and feels like it is running on one or two cylinders. Here are more specifics. The other day when It happened I put in a bottle of the Diesel 911 that Napa sells. It seemed to do the trick. In fact it ran better than it ever has. I figured my problems were solved. The temp dropped to about -20 the next day and there were no further problems. Today.....Another story!!!! I had a half tank of diesel and it was -35 below! It did the same thing as the other day so I dumped another bottle of Diesel 911 in the tank......Nothing! It took me an hour to get the truck to work. I would have to put it in park and let it idle until it idled smooth then I would get going. It would shift through the first several gears fine then it would no longer shift and the RPMs would get rather high. All of a sudden it would shift to a higher gear with no power "AT ALL"!!! It would then shift all the way through the gears into overdrive with no power to move it hardly at all. I would pull over, let it idle until smooth and then start all over again. We are going to get more cold weather this week and I am in need of some good advice as to what the problem could be. HELP!!!!!
Gebby
I am having similar problems but not as cold -4...Help us!!!!!!!!!!!!!!
no answer, but do you park it outside?
is this the cause of gelling fuel??? just an idea.
If it is gelling fuel don't you need to change the fuel filter.
change your fuel filter.
you get wax buildup in your filter. and you probably got some ice in there. drain the water out of that and change your filter
like stroker said drain your water seperator, and replace your fuel filters. that is a start make sure you buy good fuel also
thanks for the info....I will try to drain the fuel water seperator myself. Is it a hard thing to do? I also was wondering if the fuel filters were hard to replace or if I could tackle that myself as well. It is pretty cold here and I have no garage to speak of!!!
Try t find a additive Called K-100 white bottle with yellow label, Works better than the 911 stuff. most napas or truck stops carry it. And yes change your fuel fiters.
