Question...
Will the up-pipes from a 96 Stroke bold up to a 2000 Powerstroke. Just wondering if they would? Is there any difference?
The 94-97 up pipes are shorter and the driverside bottom bend is longer. They will not work without some serious modifications.
Ok, thanks for the quick response! One more question, Is the turbo flange the same there it bolts from the up-pipes to the turbo? I am looking for another flange like that, so I can maybe work on a custom charger setup.
The 94-97 is a square bolt on flange.
The early99-03 is a V band collector, also known as the "baby butt". |
So could I switch em and be able to bolt a t-3 to it??? Thanks again!
The OBS Ford is not a T3. There is not T3 flange kit available on the market for the ford. You have to make one yourself.
Why do you need a T3 flange?
What flange is it? I am just wanting to put a different charger on that I have laying in the shop, and I have access to the "flange."
What turbo do you have laying around? What is it off of?
