Replacing glow plugs - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-25-2013, 04:45 AM Thread Starter
Since ill have an extra day off this weekend was going to do my glow plugs. Curious since Ill be in there already, what else is impairitive to be done? I know theres been problems with the UVCH so Ill look into that later. Is there anything else I should look into? TIA
Omnomnom is offline
post #2 of 3 Old 03-25-2013, 10:10 AM
You could start it with the vavle covers off and make sure good and even oil out of each injector. Also put a cut quarter under the v/c to hold the clip in (quarter mod)
2000 long bed f250 4x4 auto, 38R ball bearing, intake, 4" down pipe back php six position chip low idle, 80 Eco, 140hp, 100, 60tow, 45tow, 5" lift 35 12.5 r17 bfg mud, ccv mod, lock up mod, 6.0 cooler, built 4r100,w triple disc converter 20k reese, 220k miles
strokemy2000 is offline
post #3 of 3 Old 03-25-2013, 12:03 PM
Justin@DP-Tuner's Avatar
Quoted: 47 Post(s)
Do the 50 cent mod and re-torque the injector hold downs as well as the rocker arm pedestal bolts. Those are a couple of easy things to do while you have the valve covers off.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
