Cleaning oil from the valley - Ford Powerstroke Diesel Forum
post #1 of 14 Old 03-24-2013, 09:11 PM Thread Starter
The Maddawg
maddawg89's Avatar
Quoted: 289 Post(s)
Feedback Score: 3 reviews
Hey guys! I've got a bunch of oil in the valley. I want to clean it all up and wash the engine down so I can see where my leak is.
What's the best way to clean that valley out? Not quite sure ow to do it besides mopping it up.....
2005 F250 6.0 Powerhouse Lariat
Bully GT Platinum with Quick Tricks
Bully Dog intake
Everything else stock.
Moto Metal 18in rims wrapped in 275/70 Mud Claw Extremes
2003 F250 cclb flat bed.
All stock 7.3 turtle
maddawg89 is offline
post #2 of 14 Old 03-24-2013, 10:42 PM
Justin@DP-Tuner's Avatar
Quoted: 51 Post(s)
I like to use Simple Green and then just wash it out with water after letting the Simple Green eat the grime up for a little while. If you have puddles of oil, soak them up with a rag and then do as I stated above. Simple Green is effective, but not string enough to cause damage.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #3 of 14 Old 03-24-2013, 10:44 PM Thread Starter
The Maddawg
maddawg89's Avatar
Quoted: 289 Post(s)
Sweet! Thanks mate!
Bully Dog intake
post #4 of 14 Old 03-24-2013, 10:48 PM
schlutzer's Avatar
Quoted: 18 Post(s)
I used some plastic and rubber safe industrial degreaser( use whatever you can get, simple green, etc).
Spray the valley, let it soak, then garden hose it out. Take care what you spray. A bit of water isn't going to hurt anything but direct pressure sprayed to your alternator or other connections isn't good.
To be safe I use a grocery bag over my alt. whenever cleaning something in the engine bay.
schlutzer is offline
post #5 of 14 Old 03-24-2013, 10:50 PM Thread Starter
The Maddawg
maddawg89's Avatar
Quoted: 289 Post(s)
Ok. I've got engine degreaser from AZ to do underneath but just at a loss as to how to get the valley
Bully Dog intake
post #6 of 14 Old 03-25-2013, 04:10 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Squirt bottle is what I always use
post #7 of 14 Old 03-25-2013, 04:35 AM
Njstroker91's Avatar
Dawn dish soap works well also! Awesome degreaser and it also smells nice
Sent from AutoGuide.com App
2006 f350 eclb 6 speed, powermax, billet compressor wheel, valair dual disk, 4in to 6in cat stack, afe magnum force stage 2, airdog 150, xdp sump, zoodad mod, sinister coolant filter, gauges egt oil temp and fuel pressure, cfm carbon fiber and metal cold side tub, blue spring, bpd ficm, moto metal 959 18x9 wrapped with cooper at3, custom shift knob from lilpooh, Polk audio all the way around, dashboss for monitoring
Njstroker91 is offline
post #8 of 14 Old 03-25-2013, 11:24 AM
Quoted: 51 Post(s)
You have to get creative. There is an opening between the fuel bowl and turbo that you can get down in. You can also access it from the sides.
DP-Tuner
Like us on
Justin Bochmann
post #9 of 14 Old 03-25-2013, 05:41 PM
99powerstroke62's Avatar
Quoted: 56 Post(s)
Pretty simple to pull out the spyder and tape up plenums too..
Tyler
2015 F250 CCSB Lariat- tuned/deleted
2011 Wilma F350 ECSB Lariat-
2006 Black Magic RCLB XL- In pieces
99powerstroke62 is offline
post #10 of 14 Old 03-25-2013, 07:02 PM
rocktamer's Avatar
I use purple power, stronger than simple green, still safe on all the components. I have never had an easy time cleaning the valley and have never had much luck locating my leak, mines fuel though.
1999 F250 XLT 4X4
rocktamer is offline
