trans heats up - Ford Powerstroke Diesel Forum
Old 01-24-2008, 10:29 AM
trans heats up
I have a 2001 Excursion and I was always told in the past not to pull
in OD so I was pulling a 10,000lbs trailer I had the OD off.
My tran heated right up 180-200 with in 20 miles and then I got worried and turn the OD on and it started to cool down and stayed under that 140
So is a guy to pull in OD or NOT??
Old 01-24-2008, 10:33 AM
i pull in od with my 97 and never have a problem. I find it odd it heated up that hot that fast. But im not trans tech either
Old 01-24-2008, 10:49 AM
The guy that built my brothers trans said as long as it isn't searching for gears your okay. I look at it this way a stock rebuild tranny is about $2000 that is alot cheaper than a new engine. The heat in the trans is one thing the higher rpm's is another.
Old 01-24-2008, 10:54 AM
might be time to upgrade to a bigger cooler or a secondary cooler....
Old 01-24-2008, 03:14 PM
Land Yatch Driver
silverF250 is spot on, it's ok to tow in OD as long as the tranny isn't huntin' gears. This is the same advice I got from a very reputable tranny shop. I have no issues towing in OD. A friend of mine tows a 40' toy hauler and has no problem towing with the OD on either. Just my 2 cents. Hope this helps
