FPR Shims - Ford Powerstroke Diesel Forum
Old 01-24-2008, 07:27 AM
FPR Shims
I am considering putting in a shim. What I would like to know is, if I increase my FP with either a BB, or using an allen head screw, will that cause any problems with my injectors? Any help is appreciatted..:burnout
Old 01-24-2008, 07:30 AM
BIG TRUCK, SMALL DRIVER
I have been running a shim for almost a year with no problems. I have not heard of any problems caused by the shim, but that doesn't mean they have not happened.
Old 01-24-2008, 09:50 AM
Where is the write up on this mod located, I have been tryhing to figure out how to do it, but where is it found?What is the advantage>? Not trying to hi jack this thread
Old 01-24-2008, 10:06 AM
Send a message via AIM to 4everlearning
http://www.powerstroke.org/forum/7-3-mod-help/
Old 01-24-2008, 04:02 PM
John Wood Nut Swinger
If you use the #4 allan head bolt, the threads only need to be about 1/4" long and the head should be ground down to about 1/8"-3/32" to start. Then check pressure and grind thinner as needed.
Keep Strokin'
Old 01-24-2008, 04:06 PM
Send a message via MSN to pinkfloyd
What is the ideal psi? just curious
Old 01-24-2008, 04:11 PM
i did mine with the bb and it would start harder and not idle right for about 5 mins after each start and did not notice any difference driving after it warmed up so i took it out but every trucks different and its free and takes less than 15mins so what ya got to loss by trying
Old 01-24-2008, 07:32 PM
newbie here! what does it do?????? what kind of improvements does it make???
Old 01-24-2008, 07:35 PM
It raises your fuel pressure. In most trucks they idle smoother and have a quicker throttle response.
Old 01-28-2008, 07:56 AM
So is the FPR in the same place on a 99-03 PSD as it is on the OBS PSDs? I looked at the post on how to do it on the OBS, but I just glanced under my hood the other day and what I saw didn't resemble what was in the pictures.
