2 issues: knocking in front left only in 4x4 and ac/heat only blowing out of defrost - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-23-2013, 05:16 PM Thread Starter
So just like the title says, I get a knock in the front left wheel when I put my truck in 4x4. It seems to only happen when turning but not when the wheel is full locked to either side. Help?
Second issue: started truck up today after a solid mud slingin' session and only got heat/ac through the defrost vents. I've been reading that this is usually caused by a loose connection or a vacuum hose leak/bad vacuum pump. Any suggestions? Also vacuum pump is located where? Passenger side fender, correct?
shanerbanner10 is offline
post #2 of 2 Old 03-23-2013, 05:19 PM
i'm guessing the knock on the left side might be your axleshaft u-joint and the air out the defrost only is hopefully just a bad airline somewhere in the system. I am not sure how to give you better advise, but you will need to try to hunt down an air leak and go from there.
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
