7.3 Mileage Issues - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-23-2013, 05:05 PM Thread Starter
7.3 Mileage Issues
Howdy!
I just put a wonderful 7.3 on the road. It's a '99 F-250, reg cab, long bed. I have a 1500 pound welder generator mounted inside the box. I added two extra springs on each side in the back. She sits nice.
I'm having major fuel mileage issues. For 130-140 litres of diesel, I'm barely getting 400 kilometers per full tank of fuel.
Mind you, I deleted the muffler (four inch pipe all the way down), and installed an Air Raid cold air intake. The previous owner told me that I should be getting 800 kilometers plus in the winter, and a thousand kilometers plus in the summer months.
Something ain't right. I don't know what to do.
FYI, I just changed all glow plugs, glow plug relay, valve cover gaskets, and block heater.
If you dudes have any advice, I'm all ears.
What type of mileage should I be getting?
Thanks!
Welder_Dude is offline
post #2 of 8 Old 03-23-2013, 07:08 PM
patbraaap's Avatar
woah.......thats about 7miles per gallon, i get about 15mpg with a 99 Extended cab long bed. So a little over 900 kilometers on 38 gallons of fuel (143liters) a little less in the winter like now.
E99' ECLB F250 7.3l PSD
4" MBRP Straight Pipe
DIY 6637 Intake
CCV Mod
285s
07' Front end swap
Tony Wildman 6 Pos. Chip
Gauges
X Codes
2" Mini Spring Pack
Bilsteins
T500 HPOP
08+ Mirrors
Hutch and Harpoon Mod
patbraaap is offline
post #3 of 8 Old 03-23-2013, 07:47 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Well, how do you drive it? How fast? How much idling? What RPMs do you run?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 8 Old 03-23-2013, 08:06 PM
Send a message via AIM to Flash and Flare Send a message via MSN to Flash and Flare
Clean your EBP tube and sensor, possibly replace the sensor. My mileage was in the single digits until I cleaned mine.
Flash and Flare is offline
post #5 of 8 Old 03-24-2013, 11:03 AM
chrgd2000's Avatar
Check for boost leaks, boots were killing my mpg
--7.3
chrgd2000 is offline
post #6 of 8 Old 03-24-2013, 02:01 PM
Joel's Avatar
Quoted: 10 Post(s)
WelderDude, where are you located?
Thats pretty bad mileage
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #7 of 8 Old 03-24-2013, 02:28 PM
I'm getting 16.5 in a sclb with a 4 inch lift and that's letting it run for 5-10 min in morning before I leave,avg 30 mile trip to work or store.
Diesel lineman is offline
post #8 of 8 Old 03-24-2013, 02:41 PM
Zaairman's Avatar
Quoted: 12 Post(s)
Your mileage is about half of what it should be... I think you have a massive boost leak somewhere.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
Tags
7.3 fuel mileage issues
