Old 01-22-2008, 06:36 PM
utah300rum utah300rum is offline
Question Sensor by Zoodad Mod
What is the sensor mounted just below the area you cut away to do the zoodad mod? I was thinking it was a temperature sensor?
If so does it just sense temp for overhead console or does it have a function for the engine?
The reason I ask is I have a pre made piece of metal that would make a great shroud to funnel the air into the opening to the air filter, but I would have to relocate that sensor.
Marty Marty is online now
International Threat
Yes it's a temp sensor for the overhead console.
Old 01-22-2008, 06:48 PM
DKR DKR is offline
<--Pro Cooler Racer
Agreed...if you leave it in an area similar to where it is, I don't see why you can't relocate it. Say, to a lower location, or off to one side.
Old 01-22-2008, 07:02 PM
westcoaststrokin westcoaststrokin is offline
Go Navy! Beat Army!
Actually it would probably be better. Mine always reads alittle high in the morning just do to engine heat.
Old 01-22-2008, 07:07 PM
DKR DKR is offline
<--Pro Cooler Racer
I've noticed that too, before and after doing the zoodad...and during the summer especially sitting in the sun. As soon as I start moving it adjusts though.
Old 01-22-2008, 07:14 PM
Thanks!
I am going try to get this Mod. done this weekend along with flushing my cooling sytem and filling up with Final Charge. I think I will replace the upper hose with the re-routed style, and do the bottom hose while I'm at it.
