Old 01-22-2008, 02:36 PM
smokeyd smokeyd is offline
rear shackle lift for an 01
anyone know about a rear shackle lift for an 01? need about 2 inches and there cheaper and no rough ride like an add a leaf. Thanks!!!
Old 01-22-2008, 03:11 PM
stump0331 stump0331 is offline
SNAFUSTUMP‹^›‹(•¿•)›‹^›
Tournaments Won: 1
what about some 2" blocks? that probably be just as cheap and easy
Old 01-22-2008, 03:16 PM
rankroddin250 rankroddin250 is offline
I did a shackle flip on my obs with the stock shackles it gave me about 2 inches of lift. im not sure if you can do it to a superduty or not? I just torched the revvets off flipped the brackes over and rebolted them to the frame with grade 8 1/2 inch bolts. I had to drill the holles a little bigger but it was def worth it.
Old 01-23-2008, 06:25 AM
i think it has 2 inch blocks stock? i dont think you can add blocks to it and i cant find a single 4 inch block anywhere.
and yeah i will have to see if i can flib the mount that would prob be the easiest...
Old 01-23-2008, 12:35 PM
I have 3.5 inch blocks stacked with my factory blocks... stump has 8-10 inches of stacked blocks.
Old 01-23-2008, 12:52 PM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
There is no shackle lifts for the rear. You have a choice either replace the leaf springs, add a leaf, rearch your springs, or add blocks.
Old 01-23-2008, 01:51 PM
guess going to have to go with the blocks, you guys have a good site for them?
Old 01-23-2008, 06:17 PM
heres mine.
Old 01-24-2008, 08:02 AM
thats a good set up man!!
Old 01-24-2008, 01:46 PM
like I said its on my obs so you would just have to eye ball yours real close to make sure you can do it on a superduty.
