Turbo removal - Ford Powerstroke Diesel Forum
Old 03-21-2013, 05:40 PM
Turbo removal
Trying to remove my turbo what is holding it in the back its an 03' got the clamp loosened up just can't pull the turbo out any tips/tricks all bolts are out all other clamps are off
Old 03-21-2013, 06:01 PM
I know the turbo on my 04 was a bear to get dislodged. The rear bolt was the worst to remove, kinda buried in there. Other than that, mine was kind of held in place by the turbo down pipe which I had to loosen at the clamp under the truck and pull it away from the exhaust side of the turbo before it would come out. the oil drain tube o-rings get sticky too and will require some wiggling to get out. Its a pain in the butt if it hasnt been removed in a while but stick at it, it'll come!
Old 03-21-2013, 06:34 PM
that clamp you loosened is the same clamp for the exhaust. Its a V band clamp, meaning, it falls in the "grooves" of both the back of turbo and collector. Keep undoing it til you can slide it up/over onto the collector.
Old 03-21-2013, 09:24 PM
the v band clamp holding the turbo to the up-pipes could be just stuck in place.
try and pry it off with a flat bladed screw driver.
and penetrating oil can be your best friend =)
some aerokroil or something like that
Old 03-22-2013, 01:21 AM
Thanks guys I will keep working on it
Old 03-22-2013, 04:55 AM
i used a real small punch and a real small hammer to get that back clamp to break free on mine.
