Old 01-21-2008, 09:54 AM
Jonathan734 Jonathan734 is offline
Fuel pressure test port location
Could someone tell me where the fuel pressure test port is. I believe it is on the passenger side but I must be over looking it. A picture would help alot if anyone has one. Also what should I be looking for at idle and WOT. Thanks
Old 01-21-2008, 11:47 AM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
It is on the driverside slightly off center and it has a hole for an allan wrench. It is a #4 ORB. Factory specs are 51psi +/-4psi all the time.
Anything below 40psi and you are loosing performance.
Old 01-21-2008, 01:09 PM
a1l71700 a1l71700 is offline
Stokinearly is this where you would mount a pressure gauge? Also do you know what and how many fittings that I would need to get it spaced up and ot of the way. Im looking at a gauge with a 1/4" npt connection.
Old 01-21-2008, 01:14 PM
SMKSTAX SMKSTAX is offline
KCR DIRECTOR
IIRC their is a link under the 7.3 tech files. Look under mod help.
Old 01-21-2008, 01:21 PM
eschaner eschaner is offline
You will need a 90 degree 1/4" o-ring fitting with a 1/8" pipe thread on the side that goes up for the fuel sender. At least thats what I used. Hope it helps. And they are located in the back of the fuel filter housing.
Old 01-21-2008, 01:26 PM
Yes, this is where you can put on a gauge or sending unit. You just need to get the gauge far enough away from the bowl to fit the gauge in there. Maybe a long L #4 JIC.
Look here for fitting ideas:
SAE 37° Flare (JIC) Hydraulic Tube Fittings
Straight Thread O-Ring Hydraulic Fittings
I do not like the idea of drilling a hole in the fuel filter cap or clamping a hose on the drain valve. I have done them both and the hose on the drain valve kept popping off and flooding the valley with fuel. And the cap gauge vibrated loose when I drove it.
Old 01-21-2008, 01:33 PM
So is the plug that is in the fuel unit a 1/4 npt?
Old 01-21-2008, 01:36 PM
It is a #4 ORB(O ring boss), it is also called a 1/4" ORB. Depends on who you talk to and what shop you go into. Parker employees live buy numbers and acronyms.
Old 01-21-2008, 01:50 PM
Gotcha Thanks
