How many hours to install gauges? - Ford Powerstroke Diesel Forum
post #1 of 36 Old 03-19-2013, 07:08 AM Thread Starter
LOTTS73's Avatar
I have been quoted anywhere from $350-$500 to install my boost and pyro gauges in my truck. Is this anywhere in the realm of what is should be?
01 F-350 7.3 Auto/6637 mod/Muffler delete/Pillar gauges
LOTTS73 is offline
post #2 of 36 Old 03-19-2013, 07:22 AM
Term3's Avatar
Quoted: 2 Post(s)
If you can operate a drill you could do it yourself. Several DIY guides out there and posts on DIY. If you don't like the thought of installing the sender and EGT probe then you could install the gauges, connect the lighting and run the wires to near the sender locations to save yourself some cash.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 36 Old 03-19-2013, 07:31 AM Thread Starter
LOTTS73's Avatar
Is the clamp style thermocoupler ok to use?
LOTTS73 is offline
post #4 of 36 Old 03-19-2013, 07:33 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
for the pyro???????????? Use the probe, drill and tap the manifold, you will get alot better reading and more accurate!
2000-7.3L is offline
post #5 of 36 Old 03-19-2013, 07:47 AM
Term3's Avatar
Quoted: 2 Post(s)
NO too slow of a response. I've added to my first post.
Term3 is offline
post #6 of 36 Old 03-19-2013, 07:51 AM Thread Starter
LOTTS73's Avatar
I'm ordering my gauges today, My biggest isuue is having a place to do the job. The wiring is not a problem whatsoever. I just hate laying in the dirt to work on my truck. I have drilled and tapped aluminum and mild steel before but cast is a little scarier to me..maybe just do it and go for broke!
LOTTS73 is offline
post #7 of 36 Old 03-19-2013, 07:55 AM
Term3's Avatar
Quoted: 2 Post(s)
If you use something like RapidTap fluid you'll be fine. Lay on some cardboard. LOL
Term3 is offline
post #8 of 36 Old 03-19-2013, 07:58 AM
2000-7.3L's Avatar
cardboard, plywood! My truck doesnt fit in my garage, i have a 24 x 32 garage, doesnt fit thru the door. Thats what have to do
post #9 of 36 Old 03-19-2013, 08:00 AM
Term3's Avatar
Quoted: 2 Post(s)
Let the air out of tires then maybe it'll fit. LOL
Term3 is offline
post #10 of 36 Old 03-19-2013, 08:01 AM
2000-7.3L's Avatar
4ft firesticks on the mirrors LOL, wont fit hahahaha
