Old 01-20-2008, 03:43 PM
ducttapeandbondo ducttapeandbondo is offline
odd problem.
i just got my 97 f-350's 7.3 started yesterday and the second time i started it i would barely turn, yes the batteries are fresh and and have no problem turning over and starting my f250's 7.3 idi . the f350's 7.3 looks like its under a crap load of compression or somthing is stuck.
any suggestions?... other than burn the damn thing in the middle of my yard.
Old 01-20-2008, 03:51 PM
sevenmalards sevenmalards is offline
I Graduate in 6 DAYS!
Can you describe some better symptoms? Like is it chugging, smoking, smell fuel, no power when foot on pedal, etc...
Plus a list of any mod's you have would help.
Old 01-21-2008, 06:54 AM
its turning very slowly, wont start , its like it's fighting it's self to turn over.
weak starter mayhaps?
no mods to this one. she's stock.
my other 97 f-350 has twin turbos , reliable as hell, same with my 250.
but this bastard just keeps screwin with me, it must be cursed.
Old 01-21-2008, 07:10 AM
dregul dregul is offline
mine had a weak strater did the same thing. good luck
Old 01-21-2008, 07:20 AM
Have you tried jumping it off your other truck? I've replaced the starter in my '99 last fall, it got slower and slower, then nothing.
Old 01-22-2008, 04:34 PM
yea, its getting plenty of juice, Ive tested it even at the starter..
but a weak starter? you may have somthing there.
is that a common thing for diesels?
i have a few but never had any problems, im a gas engien guy, and i had the starter in my 77 buick hears work untill 3 of the brushes wore past the holding screw and snapped off and the forth was never connected.
Old 01-22-2008, 04:54 PM
everything wears out at some point. If it has plenty of juice, and the solinoid is good, then it can only be the starter.
