Headlight question
I was putting in new headlights and ended up finding a short in the driver side headlight connector. Today I installed a new connector and the headlight now works. Everything looks good until I try to flash the high beams and nothing changes. When I push the lever forward, the lights go out completely. I marked the wires to make sure I spliced the wires correctly but it seems to me I still messed up. Does anyone know what may cause this issue ?
Maybe the high beam filament is toast?
What do you mean by filament? I know the high beams worked before I wired the new connector. What would I do to fix it if this is the problem?
you obviously mixed up the wires somehow.... or blew a fuse or maybe the relay is toast.
check fuses first then find a good dc volt meter to figure out what's happening. start with the headlight connector and work back from there. |
Ok. I'll check for blown fuses. I just wonder why the wires on the new connector are different colors than factory. I mean it had blue in it. Not sure how to use voltage meter but I guess I will recheck my wiring again. Thanks!
Wire color is simply an easy tool for tracing on wiring diagrams. Aftermarket companies don't always care about matching factory style because they don't have to. Look at your factory plug. You'll see what order the wires go into it. Make sure they go into the new plug in the same order. If that's good, you have another problem. Does your passenger side work properly? If so, swap bulbs and see if the problem follows the bulb. If it does, the bulb is broken. If it doesn't, there is a problem in the wires somewhere. You said brights worked before you changed connectors, so either you messed up the wiring, or didn't make a solid connection in your splice.
Voltmeter is easy. Black lead goes to ground, red lead goes to hot. It doesn't matter too much if you get the leads backwards in this type of measurement. You'll simply read -12vdc instead of +12vdc. |
Ok. I triple checked the wiring of the new connector compared to factory wiring. It is the same. I then pulled new bulbs out and tried the old bulbs. Same result as with the new ones- no high beams. I then checked fuse #16 I believe, which after researching has led me to believe is the high beam fuse, and replaced it with another 30 amp fuse. Still get the same result. After searching, I have found several people have this exact same problem. The solutions have been the green/black wire being knicked up(therefore causing it to go to ground) and blown fuse (which I have already found to be fine). I am planning on getting a meter to check voltage next since the other things have not fixed it. Thanks for the help and I'll keep everyone updated to what the fix was when I find it.
