Question about CCV system - Ford Powerstroke Diesel Forum
Old 03-18-2013, 02:52 PM
On my 02 is there a way to disconnect the CCV off the intake and run the truck for a few weeks to see if it is causing my smoking issue in the mornings? Also I don't want to make a mess in the engine bay if the tube is disconnected! And I don't want to spend anymore money on a ventilation kit either. Thanks
Chris
Old 03-18-2013, 03:02 PM
WNY Biodiesel Co-op
I ran a 5/8 hose off the valve cover dog house under the truck back past the doors, mine is a crew cab . So the hose was about 6 ft long and ended near the tank. I plugged the hole in the intake with silicone sealer. My intercooler is clean but I will see a little smoke coming out the hose. If your exhaust is smoking you have excessive blow by which would = worn valve guides or bad rings and low compression . Possible worn injectors. I had #6 smoking at idle but was clean burning above 13000 rpms. I changed the injector yesterday and no more smoke.
Old 03-18-2013, 03:46 PM
My lowest compression is 390psi in number 5. The rest of the cylinders are at 420. 8 brand new injectors. Checked excessive blow by out the oil fill tube and just a light stream of smoke and that's all, the oil fill cap didnt move at all.
Old 03-18-2013, 03:55 PM
Feedback Score: 5 reviews
What does it mean why you have a bit of blow by... like it will slowly move the cap off the filler tube?
Old 03-18-2013, 03:57 PM
The cap will just sit there, when you take the cap off the tube a little smoke comes out, but with the cap upside down it doesn't move a bit
Old 03-18-2013, 04:07 PM
Then you're good. A little smoke is normal.
And smoke at start up is also normal. It should clear up fairly quickly though.
Old 03-18-2013, 04:22 PM
Oh no it doesn't clear up until high idle is done with and the engine has really warmed up, and sometimes it misses too.
Old 03-18-2013, 11:42 PM
What color is the smoke?
Old 03-19-2013, 08:19 AM
Blueish white smells like raw fuel. Sometimes when I start it I get a nice whiff of burnt oil that comes out the tail pipe but only when cold though never hot. Also if I am rolling while the engine is already hot, and I put truck into neutral and rev it a big cloud of blue comes out. I do have some oil consumption too about 1-3/4 quarts every 4000 miles.
Old 03-19-2013, 11:34 AM
Well the white smoke that smells like raw fuel is, you guessed it, raw fuel. This is most likely from a faulty component in the GP system. A little white puff is okay at first start-up, but excessive smoke means there is a problem.
The blue smoke is definitely oil. If I had to guess, I would say injector o-ring that did not seal correctly. Your compression numbers look too good for it to be a ring.
