Old 01-20-2008, 10:43 AM
jnhuber jnhuber is offline
Hub Bearing Assembly
Do you have to replace both left and right or can you just do one side. I understand if one is bad the other could be on its way but the whole money thing is coming into play.
Old 01-20-2008, 10:48 AM
mschn99 mschn99 is offline
just replace the bad one.....since they are sealed cartridges...the lifespan isnt predictable so there is no point in replacing a good one. Ive seen them go 25k and fail...and ive seen them go 250k and still be good....
SMKSTAX SMKSTAX is offline
KCR DIRECTOR
Had my left replaced on my 04'. Still have the original right.
jus playn jus playn is offline
best thing is both at once
Old 01-20-2008, 10:57 AM
silverF250 silverF250 is offline
No the best thing isn't both at once. Only replace the one that needs it. Why replace something that isn't a problem. If you were talking the balljoints on one side yeah I would do both but not the hub bearings. You should on the other hand keep an eye on the one that isn't replaced.
Old 01-20-2008, 12:17 PM
Once you notice the bearing have gone is it ok to drive it until the parts come in or should I make her sit?
Old 01-20-2008, 12:24 PM
sea71 sea71 is offline
After seing mine once I got it off, I would suggest leting it sait as much as possible. The popping you are hearing is the bearings shearing and hanging up, filling your hub and every other void with ground metal.
Old 01-20-2008, 12:26 PM
The grinding has stopped its the only reason I can tell it is bad it my wheel has about 1/4 inch play in it when I lift it. Is the fact that its not grinding good or bad?
Old 01-20-2008, 12:36 PM
Diesel Monkey Diesel Monkey is offline
Ever see a truck loose a whole wheel on the freeway? Not very safe idea to keep driving it.
Old 01-20-2008, 12:37 PM
Thats all I needed. Thank you
