Old 01-19-2008, 04:18 PM
siloped siloped is offline
Battery cables
Anyone know where I can find new positive cables other than the $177 ford wants? The corrosion was past the terminal when I cut the wire and isulation back, poof more corrosion. Starting to run out of cable to shorten up
Old 01-19-2008, 04:27 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
You can make your own cables
Old 01-20-2008, 08:06 AM
have you done this? how complicated is the pos side withe the starter relay and the starter and such, I've looked at them breifly and it lookes like they slit here and splice there and such. I've looked into making my own out of welding lead (wich I will be doing for the neg) but the pos just looks a little to complicated.
Old 01-20-2008, 08:11 AM
Are all the cables bad? Just replace the bad ones.
Old 01-20-2008, 03:17 PM
not sure. I definatly know that the end where the battery terminal is, is bad, and that looks like it goes to the starter. the other little one at the bat goes to the solenoid if I'm not mistaken, and thats where it looks to be getting confusing
Old 01-20-2008, 07:46 PM
Jetmek319 Jetmek319 is offline
Send a message via MSN to Jetmek319 Send a message via Yahoo to Jetmek319
Take a look at these. Look like they are pretty healthy (2/0 gauge).
Optima battery cable for Ford diesel trucks Battery cable for Ford diesel truck [SF0115] - $79.95 : Batteries Are Us
Old 01-20-2008, 07:55 PM
Missed one!! oops...
Ford F-250 Super Duty Battery Cable 2004 - AutoPartsWarehouse.com
