Weird chime sound - Ford Powerstroke Diesel Forum
Old 03-17-2013, 03:01 PM
Weird chime sound
My truck is doing some real weird chime noises.
When I just turn my key on and let it sit after about 15-25 seconds it starts beeping at me. It beeps 5 times quits and beeps 5 more times and quites and repeats this around 5 times. then quits and wont do it again. it also does this when the truck starts.
Also when I turn my truck key to Accessory door open or closed the chime as sounds like a door alarm starts beeping and wont quit.
any ideas?
GEM issue?
Old 03-17-2013, 05:54 PM
Re: Weird chime sound
Anybody got an idea?
Old 03-17-2013, 06:58 PM
It sounds like an issue I have. If its a 5 beeps in a series of 5 sets it refers to an airbag issue. My issue is the light is missing from the dash thus my airbag light should be on
Old 03-18-2013, 02:32 AM
Weird chime sound
Put your seatbelt on. Lol
Couldn't help it.
Sent from AutoGuide.com App
Old 03-18-2013, 02:39 AM
Hmmm I had it on a scanner this weekend and it showed no issues in the air bag system.
Couldn't help it.
Honestly I wouldn't doubt the sensor for that is bad. But no worries I do wear my seat belt. That bulb may be burnt out also *face palm*
Old 03-18-2013, 05:02 AM
same situation here. Found that my airbag light was bad. Replaced with 12v led one, soldered it in, and alls good now,..2yrs.
Old 03-18-2013, 07:21 AM
If the bulb is out the chime goes off? Hmmmm
Old 03-18-2013, 07:37 AM
Ya, the bulb is out, the noise will happen... Google it, and you'll read where they use resistors and what not, but i had no luck that route. Went to radio shack, got me a red 12v led, soldered it in, and BAM, no more noise
Old 03-18-2013, 08:19 AM
Well I'll just go get a bulb and replace it then. The chime is so obnoxious
Old 03-18-2013, 10:31 AM
What type or size of bulb is that
