  #11 (permalink)
Old 01-20-2008, 08:17 AM
01TNfarmer 01TNfarmer is offline
ok, thanks for the help. also, the O-ring, does it go on the lid?? thats how my dodge is....or does it go aroun a filter end or something...thanks
  #12 (permalink)
Old 01-20-2008, 09:25 AM
99bigred 99bigred is offline
on mine there is one around the lid
  #13 (permalink)
Old 01-20-2008, 09:37 AM
stewy stewy is offline
there should be an o-ring for around the filter base and a beveled o-ring for the lid and the beveled edge faces up if i remember correctly, good luck
  #14 (permalink)
Old 01-20-2008, 10:14 AM
Hank Hank is offline
C.P.A. Officer
I agree
Check the packaging for the correct position of beveled gasket. I never remember but it is usually published on the packaging.
Really fairly easy once you've done it once. Good luck. Come on back if you have a problem.
  #15 (permalink)
Old 01-20-2008, 10:49 AM
skip97IH skip97IH is offline
Send a message via MSN to skip97IH Send a message via Yahoo to skip97IH
Not sure if it is the same as the 97 7.3 but if you get the puralator filter from advance it all comes as one unit lid and all.
