Oil cooler question - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-17-2013, 07:36 AM Thread Starter
Oil cooler question
Hey guy's I have a bit of oil in my rad this morning, and think it may be coming from the oil cooler. Question is, do you have to rplace the whole cooler or can you just replace the o rings?
Stock!
7.3L - 03/F-350 CC Fx 4X4
4inch turbo back Flow Pro Exhaust
Edge evolution II programmer/monitor
AFE intake
stock is offline
post #2 of 4 Old 03-17-2013, 07:39 AM
kystanger's Avatar
I'm pretty sure if you have oil in your coolant the whole cooler need replacing. All orings and the gaskets fix is oil leak on outside of engine.
2008 f350 4x4 Stock
(SOLD)2001 f250 4x4
319,000 miles and counting.
6637 intake, 4 inch MBRP exhaust,gauges,203 degree therostat, leveling kit, transgo tugger kit, front and rear mag-hytec diff covers, more to come.
kystanger is offline
post #3 of 4 Old 03-17-2013, 08:28 AM Thread Starter
Thanks, anyone know where to buy a good quality oil cooler at a fair price/
Stock!
AFE intake
stock is offline
post #4 of 4 Old 03-17-2013, 05:33 PM
BSkopnik's Avatar
Oil cooler question
O-rings will fix leak into coolant aswell. Autofair ford is a good choice for oem parts. They are a vendor here. Dylan is the man to talk to.
Sent from AutoGuide.com App
02 F350 CC LB 4x4 Lariat
Done: K&N CIA, Torklift Camper tie down system, Firestone Ride Rite Air Suspension(Dual guage control, w/ reservoir tank), Autometer 3 Pillar guage(Boost,EGT,Tranny Temp), Vision Type 81 19.5" w/ Goodyear G622 RSD 245/70r19.5 LRG, 03-07 power/heat/light mirror conversion, Sinister Coolant Filter kit.
ToDo: Powerslot Cryo rotors, Hawke SD pads, 6.0L Tranny Cooler, Oil Temp/Pressure, Fuel Pressure and Diff Temp guages.
BSkopnik is offline
