  #11 (permalink)
Old 01-19-2008, 05:37 PM
99Smokin73Stroker 99Smokin73Stroker is offline
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
Understandable, but I could see 3 hours maaaybe 4
  #12 (permalink)
Old 01-19-2008, 05:41 PM
najaf4life najaf4life is offline
Look Ma.. No Hands
well when I put on my exhuast the stock on just fell out.... but the new 4'' down pipe was a hassle untill I took a ratchet strap and put on hook on my tranny and the other on the frame and moved it untill it would fit... quick and easy that way...
  #13 (permalink)
Old 01-20-2008, 09:44 AM
Tex99F-250 Tex99F-250 is offline
I put a 4in on mine about a month ago. took me two hours. but had a lift and victor wrench. my whole exhaust fit good, no rubs anywhere. im a happy camper
  #14 (permalink)
Old 01-20-2008, 09:59 AM
Down the road if ya'll notice any vibrations, look at the area where the tubing passes over the trans crossmember. Exhaust kits on 7.3's are known to migrate towards one of the bolts holding it to the frame causing vibration against it. Mine did and there have been at least a half dozen posts on here with members who have had the same issue. You can adjust it, but it will likely do it again. We just welded an exhaust hangar to the crossmember and to the tubing forcing it away from bolt.
