got P0781 code while ****ing around
977 views 1 reply 2 participants last post by  NCHornet
#1 ·
i was ****ing around in traffic was getting pissed and got heavy in the pedal when i could and the overdrive light started flashing so i pulled over through my hazards on turned truck off and restarted it and the light went off and i went down the road pulled into a parking lot and checked the codes and got the P0781 which i heard before it was a shifting from 1st to 2nd malfunction idk if im right or not?????? what could be wrong??????
#2 ·
Your right it is a malfunction in the shift between 1-2nd, probably the clutch packs started slipping or..... ????? I would refrain from this or your trans may not like you much longer. You have the shift kit, but I would prefer a complete VB. If it does go call BTS and you won't have to worry about these types of codes again. As long as it is still shifting fine now I wouldn't sweat it.
Kevin
