Old 01-18-2008, 04:47 PM
firemedic355 firemedic355 is offline
Blowin Smoke
What is this Sensor on my intake?
So after a little engineering and modification I've made my own intake out of high density 4" black plastic sewer pipe and a fram filter. I just didn't want to blow $52 on a Napa 6637 right now. Anyway, does anyone know what the little sensor is that was poking through the back of my factory air box just below the filter? I just twisted it out and left ot hanging there but I'm wondering if it's gonna make me throw any codes now?
Old 01-18-2008, 04:49 PM
mschn99 mschn99 is offline
thats your intake air temp sensor...and you want it as close to the filter as possible. It reads the temp of the air right before it goes through the filter...so you want it do do just that. As long as its connected it shouldnt throw any codes but you dont want engine heat to mess it up any more than you have too....
Old 01-18-2008, 04:51 PM
Blowin Smoke
so if I don't have an air box anymore what can I do with it? All I have is a pipe with a filter on the end of it.
todd todd is offline
and that filter is avalible at truck shops for 25-30 instead of napas price
Old 01-18-2008, 04:52 PM
just zip tie it somewhere beside you filter its just reading the temp
Old 01-18-2008, 06:11 PM
alabamafrog alabamafrog is offline
Powerstroke Techie
That sensor is just to tell the computer the incoming air temp. Since you are now drawing air from all around the engine compartment then it is okay to just tie it up out of the way somewhere and it will still read the ambient air temp in the area. I have mine tied to one of the brake lines.
Now you got an early 99 so all you should need is a 3" PVC 45 and an air filter to do the standard DIY open air intake. Here is a part number cross over list for the filter. Surely you can call around and find a better price on one of them. I buy my Baldwin brand ( Baldwin Filters ) for $38 and it lasts about 2 years. So for around $40 and 10 minutes you can do the normal DIY intake. Cheap insurance for a $10,000 engine.
PA2818 NAPA GOLD 6637
PA2818 SCHUPP SL12903
PA2818 WIX 46637
PA2818 WIX 546637
PA2818 WOODGATE WGA1138
PA2818 ACDELCO A1474C
PA2818 AIR REFINER ARM08-5011
PA2818 BALDWIN FILTERS PA2818
PA2818 BIG A 94637
PA2818 CATERPILLAR 3I0003
PA2818 CARQUEST 88637
PA2818 CUMMINS 2912986
PA2818 CUMMINS 3912020
PA2818 DONALDSON B085011 H
PA2818 DONALDSON ECBO85011 H
PA2818 DONALDSON ECB085011 H
PA2818 FLEETGUARD AH1141
PA2818 FLEETRITE AHR81141
PA2818 FRAM CA6818
PA2818 GFF AF359214
PA2818 GENERAL MOTORS CORP. 25177209
PA2818 HASTINGS PREMIUM FILTERS AF2329
PA2818 HERCULES B085008
PA2818 KRALINATOR LA1458
PA2818 LUBER-FINER LAF2533
