Old 01-18-2008, 03:27 PM
scheidt27 scheidt27 is offline
flushing trans is MESSY
man i flushed my tranny and put in the valve body today. what a mess!! i got 16qts of the old stuff out before i had enough of it and replaced it with 16qts schaeffers synthetic. IS getting 16 qts out enuff for a flush?
Old 01-18-2008, 04:56 PM
Fullspeedjunky Fullspeedjunky is offline
I think it holds 18 quarts
Old 01-18-2008, 05:02 PM
alabamafrog alabamafrog is offline
Powerstroke Techie
Mine has a drain plug on the tranny pan and one on the torque converter and after a full drain it takes about 17 to fill it back up.
Old 01-18-2008, 05:19 PM
yea i drained out sixteen and put back in sixteen. i followed theose directions that everyone goes by, i had the wrong hose setup what i was flushing it out the treturn line and got fluid all over me and the floor a couple times, after i was up to 16 qts worh of replacement i said the heck with it good enough?
Old 01-19-2008, 03:17 AM
NCHornet NCHornet is offline
Powerstroke Techie
The VB is where it get's messy, because there is no way to get the fluid out that sits on top of it!! But simply flushing the trans fluid shouldn't be a mess at all. Did you shift through the gears like you were suppose to? With my 6.0 cooler mine holds right at 20 quarts so for me that would mean I still had a gallon of old fluid in there and I would never settle for that. Not sure why you didn't pump another couple quarts through it for a full flush. Your trans isn't going to die from this, you should be fine but it's not ideal.
You'll be okay.
NCH
Old 01-19-2008, 05:59 AM
for some reason the hose setup i was using was not working, it kept shooting back out the backside by the clamp, adjusted it several times, i just was at my wits end cuz some stuff went wrong installing my vb and just wanted to get it together and be done, my patience had ran out. Now would it make sense to flush a couple more gallons out cuz i have a couple more gallons of the schaeffer left, or doesnt it matter now that its now all mixed together. I can put the other two gallons or so i have left in there if its gonna help.
