Parking brake - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-15-2013, 07:39 PM Thread Starter
natemoses13's Avatar
Parking brake
My parking brake pedal is disconnected from the cable and the pedal is stuck down. The release is also broken. What's the best way to fix these things?
E99 F350 crew cab dually flatbed. 2wd 6-speed. Boost and egt gauges. 6637 intake. Superchips flashpaq.
L99 F350 crew cab dually flatbed. 2wd Auto. Billet TC & aux cooler. 6637 intake. Superchips flashpaq.
natemoses13 is offline
post #2 of 5 Old 09-02-2013, 08:52 PM Thread Starter
I have replaced the cable 3 times now and it just broke again. I am pretty sick of replacing it. What the heck is the deal, and how do I get a consistent parking brake?
post #3 of 5 Old 09-03-2013, 04:28 AM
usteffenhagen's Avatar
Subscribed.... Mine is all messed up too
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #4 of 5 Old 09-03-2013, 04:38 AM
ZMANN's Avatar
Quoted: 1586 Post(s)
mine works fine and I set it pretty hard often and lock it for a theft deterrent
if your not getting oem cables that could be an issue ( what is breaking?) and I would find a newer/fix
your release the system is simple on a SRW but not sure on a DRW
We Miss you Ronnie
ZMANN is offline
post #5 of 5 Old 09-03-2013, 04:57 AM Thread Starter
it is the front cable, and it has snapped in different areas each time. First one was the head that rests inside the parking brake assembly, second was the cable itself about 6 inches from the head on the cable in the assembly, and this last one broke on the head that attaches to the coupler under the body.
