- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
help. Battery light!!!!
I had just replaced my alt. due to the battery light flashing, but going away when accelerating, but now the light has came back and is on all the time. the batterys are charged and putting out the correct volts, and it has a new alternator? what can it be????// Thanks!
| Sponsored Links |
Did you buy one of the Lifetime warranty crap alternators from AZ, Advance or one of the larger stores? If so I bet the alt is bad. I had had to replace 3 before getting a good one. They use the cheapest parts they can in the rebuild. Their starters are even worse. Now I only deal with DB electrical and I know I have a good unit. Check the voltage that the alt is putting out, should be around 14 volts. Could also be a loose or burnt harness so troubleshoot it. Good Luck |
thanks guys. it is one of those crap advanced ones. I am going to check the out puts on it today when i get to the shop, the light also has been off all day? werid... i once had to replace my hubs 3 times because of deffective crap from adavanced.. oh yeah i have airbag issues too, but the light burnt out so it just beeps everynow and then like the seat belt.
did you have the batts. load tested? if they are not able to hold a charge youll run into that problem, even with a new alt.
| Sponsored Links |
