Smoke upon cold start - Ford Powerstroke Diesel Forum
post #1 of 16 Old 03-13-2013, 02:09 PM Thread Starter
The truck is an 02 has 140,000 miles. I started it this morning and she blew a huge puff of smoke and it smelled like burnt oil. She has been using oil for a little while now about two quarts every 4000 miles. I have had a cold smoking issue for a couple years now and it smokes like a freight train, but it smells like fuel. My number 5 cyl has 390 psi compression. I have changed and replaced everything related to the fuel system, GPS, relay, uvch, Uvc gaskets. There is too many things I've changed to list. Any ideas? I'm thinking valve seals. Thanks for the help!
hondaracer315 is offline
post #2 of 16 Old 03-13-2013, 04:53 PM Thread Starter
Any ideas why I am smelling burnt oil? Should I mess with the CCV?
post #3 of 16 Old 03-14-2013, 09:33 AM Thread Starter
Why is it everytime I put the truck in neutral while I'm rolling down the street and rev the throttle it will blow out a puff of blue smoke? Also if I put it back into drive and put the pedal to the floor from a coast about 30mph it will blow a puff of blue then black smoke comes out why? Any help?
post #4 of 16 Old 03-14-2013, 12:21 PM
timmyboy76's Avatar
did a little reading, and alls pointing back to bad injector/s or injector o-rings. Have you done the oil cap test, to check for blowby?
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #5 of 16 Old 03-14-2013, 12:58 PM Thread Starter
New injects all 8 oil cap test showed nothing at all. Barely any blowby just some smoke out the fill hole and the cap just sits on the tube that's it!!
Chris
post #6 of 16 Old 03-14-2013, 02:44 PM
Tj Krawler's Avatar
Have you checked the fuel bowl for oil yet?
I'd guess injector O rings, or turbo seals.
Alan
2000 F-350 CC LB DRW 4x4 XLT Auto
- Intake
- Exhust
- ScanGauge
Tj Krawler is offline
post #7 of 16 Old 03-14-2013, 02:48 PM Thread Starter
Fuel bowl no oil turbo rebuilt with all new seals. I've replaced everything I can think of. Any other ideas?
post #8 of 16 Old 03-14-2013, 05:16 PM
timmyboy76's Avatar
with it idling/smoking, unplug the MAT sensor, located in the middle of the spider assy...i'll post "thread" when i find it.
post #9 of 16 Old 03-14-2013, 05:22 PM
timmyboy76's Avatar
http://www.powerstroke.org/forum/7-3...at-sensor.html
post #10 of 16 Old 03-14-2013, 09:09 PM Thread Starter
Replaced Mat Sensor icp sensor ipr sensor air intake sensor inside the airbox. Any other ideas?
