Rear Brake Diagrams - Ford Powerstroke Diesel Forum
Old 01-16-2008, 03:23 PM
Rear Brake Diagrams
Anybody have parts diagrams for the rear brake system on an 01 250? I've spent the last 30 minutes perusing the web looking for one to no avail, and want to make sure of a part before I special order it.
I think it's called the caliper mounting bracket, but I want to verify before spending the dinero at the parts house.
Thanks,
Old 01-16-2008, 03:27 PM
duct tape & zip ties
Whats the problem. I don't have a diagram. But the brakes on a 99-03 are the same. I have done my brakes on my 2002 alot and have had to replace alot of the parts at one time or another.
If you are wondering what the part that bolts to the backing plate that the caliper mounts too is called. Yes it is the caliper mounting bracket. It is location specific, ie driverside front, driverside rear, passengerside front, passenger side rear.
An idea for you if you have some junkyards around why not check there for this part before you order it.
Old 01-16-2008, 03:30 PM
Im not sure if you can buy it seperate but Carquest sells them with a caliper, and yes it is a caliper mounting braket.
Old 01-16-2008, 03:33 PM
Autozone, Parts America ( Advance Auto, Murrays Discount Auto Parts) sells the mount seperate. But it has to be ordered and usually takes one to two days for delivery.
Old 01-16-2008, 03:47 PM
Ive got a couple used ones ikeep in my tool box, when a truck comes in for brake problems (usualy stuck slide pins) Ill trade them out.
