fuel tank problem
hey boys Im one of them guys who likes to drive and drive long after i should fill up and iv been having this running out of fuel problem my truck shows 1/8 tank and stops dead in the road. after getting it to the station it doesnt fit the capasity of the tank in it which is telling me there is still fuel in the tank. Why is it not sucking the tank dry? it didnt do this when i bought it it runs out before the fuel light even comes on sometimes it will show 1/4 and run out then i turn the key back on and it shows empty, doesnt make much since to me and please spare me the fill it up before it runs out comments my dad likes to borrow it and bring it back empty
check your sending unit (properly grounded, pull it and clean it, or replace it)
also check to see that there isnt a dent in your tank, happens a lot off roading. |
fuel tank problem
Definatly do the hutch mod I have done many of them for me and friends all with the same symptoms order a pickup foot also when you order the hutch mod kit it's most likely broken and floating around in the tank
Sent from AutoGuide.com App |
fuel tank problem
Yep it is the damn mixer valve, easy fix! 1.5-2hrs if you have a little wrench knowledge
fuel tank problem
Unfortunately they are out of stock on those kits at this time, just read guzzles page and build your own kit. Order a new mixing chamber from the link on guzzles site.
fuel tank problem
there's 2 main reasons of the Hutch mod. 1 is to remove the screens and mixing chamber completely, so it doesnt plug up, later...and 2, is to re-route the 'return" line, from the mixing chamber, to remove ALL air in the "return" side system. You'd be surprise how "less" noisy, the engine will be, doing so...
I did Hutch with a booster pump (with Pre-pump crud filter) and deleting the foot valve. I also extended the pickup tube into the sump. Last, did harpoon as well! Well worth the effort and gained nearly 5 addl gal of tank volume.
If I were to do it again, I would buy a kit as it just takes a lot of time to drive around get the pieces parts! |
