what gear ratio do I have? - Ford Powerstroke Diesel Forum
Old 03-10-2013, 03:49 PM
Tried a quick search but didn't find an answer. How do I find out what gears are in my axles? Is there somewhere I can decode the VIN or something?
Old 03-10-2013, 03:58 PM
Most have 3.73
Old 03-10-2013, 04:09 PM
An oasis report from a Ford dealer.
Old 03-10-2013, 05:03 PM
You can look on your door plate and get the axle code , pretty easy search from there
Old 03-10-2013, 05:13 PM
I think the diff cover bolts will have a sheetmetal tag stamped with the ratio.
Old 03-10-2013, 05:16 PM
with all three^^^.
You can also count drive shaft revs per tire rev... (With help)
Old 03-10-2013, 06:16 PM
Thanks for all the replies. I will crawl underneath and check when it stops raining
Old 03-10-2013, 07:21 PM
Easy... SRW or DRW? What tire size and what RPMs at 70 MPH? If you're around 2000 RPMs on stockish tire size at 70, you have 3.73s.
Old 03-10-2013, 07:34 PM
It's a single rear wheel, stock tire size, 265 iirc. 70mph without OD? 2000 rpms @ 70 sounds about right.
Old 03-11-2013, 11:08 AM
Tag on the inside drivers door frame looks like the one on the link -
http://i1086.photobucket.com/albums/.../IMG_8017.jpg-
look bottom center where it says axle and then do a search with that code and it will tell you. Or you can crawl under and look for the tag on the diff bolt but i believe you still have decipher
The following lists the gear ratios on rear axles.
31 - 3.73 non-limited slip, F-250/Excursion
32 - 4.10 non-limited slip, F-250
41 - 3.73 non-limited slip, F-350
61 - 3.73 non-limited slip, F-350
73 - 4.30 non-limited slip, F-450
75 - 5.38 non-limited slip, F-450
78 - 4.88 non-limited slip, F-450
81 - 3.73 non-limited slip, F-350
88 - 4.88 non-limited slip, F-350
95 - 5.38 non-limited slip, F-550
98 - 4.88 non-limited slip, F-550
C1 - 3.73 limited slip, F-250/Excursion
C2 - 4.10 limited slip, F-250/Excursion
C3 - 4.30 limited slip, F-250/Excursion
D1 - 3.73 limited slip, F-350
D2 - 4.10 limited slip, F-350
D3 - 4.30 limited slip, F-350
E2 - 4.10 limited slip, F-350
E3 - 4.30 limited slip, F-350
EW - 4.10 limited slip, F-350 (ambulance package)
F1 - 3.73 limited slip, F-350
F2 - 4.10 limited slip, F-350
F6 - 4.56 limited slip, F-350
G3 - 4.30 limited slip, F-450
G5 - 5.38 limited slip, F-450
G8 - 4.88 limited slip, F-450
GW - 4.88 non-limited slip, F-450 (wide frame)
K5 - 5.38 limited slip, F-550
K8 - 4.88 limited slip, F-550
KW - 4.88 non-limited slip, F-550 (wide frame)
