white smoke - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-13-2008, 05:40 PM Thread Starter
white smoke
2001 7.3 has white smoke coming from the exhaust and it has a strong diesel smell. it is hard to start in the morning if not plugged in. sometimes the smoke will clear up (just for a minute) it also idles rough.
jayson is offline
post #2 of 4 Old 01-13-2008, 05:45 PM
duct tape & zip ties
bigcountrysg's Avatar
I will suggest you have a few tests ran. I would start with an injector buzz test. This will tell you if your injectors are working. An injector contribution test this will tell you if you have any faulty injectors. To me it sounds like an injector problem. Now it could be caused by a faulty under the valve cover wiring harness. I would check the connections at the valve covers and see if they are good tight and clean. Also scan your truck for codes. Even though your cel is not lit up does not mean there are no codes stored in the pcm.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #3 of 4 Old 01-13-2008, 05:45 PM
bullydoller's Avatar
possably a bad injector or two>>>
2007 F250
6 Speed
3:73 Gears
Autometer Guages
Straight piped w/6" tip
17x10 mickey thompsons\buckshot mudders
Custom tuned SCT Xcal2
bullydoller is offline
post #4 of 4 Old 01-14-2008, 06:49 AM
my19997.3's Avatar
Mine did the same thing only after a few months of owning it. My buddy retired from the local Ford dealership and had me bring it in to them (under the books) to have it tested. The #6 injector went out on it. I bought another injector and replaced it. Now the truck runs like the day I bought it.... First time I ever did an injector, just had to find some info on the net on the replacement process.....
Leon
2003
F-150 Lariat 4x4
Stock for now........
my19997.3 is offline
