thunk - Ford Powerstroke Diesel Forum
Old 03-09-2013, 02:20 PM
thunk
while driving today i kept hearing a thunk when turning. i could feel it in the floor board. any ideas. 2001 srw f350 ccsb 4x4
Old 03-09-2013, 03:59 PM
was it only when turning - or should i say has this only happened when turning - the last thump i dealt with was my carrier bearing going out - it blew out - check for play in your driveshaft
Old 03-09-2013, 04:37 PM
seemed to be only when turning while going slow. i do have alot of play in the steering wheel.
Old 03-10-2013, 10:03 AM
The thunk I was hearing and feeling in my floorboard was my sway bar end links, replaced them and the thunk went away
Old 03-10-2013, 10:27 AM
thunk
I as well have that exact problem as well. Only when I turn. How much did those sway bar links cost
Old 03-10-2013, 10:28 AM
I think I spent around $245 for the pair front and back at napa
Old 03-10-2013, 10:33 AM
thunk
Hmm, it's in the front. I also have loose turning as the OP said. What can I do to fix that? The truck I have is 12" lift on 44's.
Old 03-10-2013, 11:03 AM
You may have to go thru the lift manufacturer to get the end links
