Weird clunk - Ford Powerstroke Diesel Forum
Old 03-09-2013, 01:20 PM
Weird clunk
Have an 01 F250 with 8 in lift and 38s. Has had all this since 03 when i bought it with 25000 miles, now have 106000 and have had zero issues minus the normal wear and tear stuff like ball joints and a hub assembly. Have recently started hearing a clunk when turning left, only happens when turning left. Started troubleshooting it today. Everything is tight as far as tie rods and steering goes. However there are 2 lines on the left side of the radiator that appear to be power steering lines going to a radiator i believe that noticeably move, like a valve is sticking in the power steering pump causing the lines to jump so to speak and i hear the clunk at the same time. I'm assuming it's just the power steering pump on its way out the door. Has anyone experienced this before?
Old 03-09-2013, 04:29 PM
You might check your sway bar/end link bushings. Mine makes a clunk noise when I hit a bump while turning and that's what's wrong with mine. Just an option...
