buzzing sound from flasher - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-01-2006, 10:10 AM Thread Starter
02ROB's Avatar
I have an 02 7.3 psd yesterday it started making a buzzing sound from the flasher. kind of a on and off buzz. I bought a new flasher and that did not help it is almost like someone is turning a switch on and off. The realy weird part is that if I step on the brake pedal it stops or if I use the turn signal it stops.. help if you can
2002 f-250 4x4 ext. cab 7.3 psd,banks 4 inch monster exhaust,auto meter gauges, TS 4 bank 6 pos. chip.
02ROB is offline
post #2 of 6 Old 09-01-2006, 12:28 PM
multifunction (turn signal) switch is bad.....ill 95% garantee it!!!
mschn99 is offline
post #3 of 6 Old 09-01-2006, 01:08 PM Thread Starter
02ROB's Avatar
is that the one in the steering coloum
02ROB is offline
post #4 of 6 Old 09-01-2006, 02:01 PM
03f3507.3's Avatar
yep i'll have to agree both me and my dads superdutys have had the same problem!
2003 F-350 CC LB BAMF EDITION
Built 04.5 CTD with a Giant set of twins for power
2008 F-350 CC SB...tow rig for the Fummins
03f3507.3 is offline
post #5 of 6 Old 09-01-2006, 05:38 PM
Yes, its the actual turn signal switch on the column. Virtualy every exterior light controll is run through it.....
mschn99 is offline
post #6 of 6 Old 09-02-2006, 08:29 PM Thread Starter
02ROB's Avatar
Thumbs up
I bought one today and put it in and it seems to have done the trick. thanks for the advice
02ROB is offline
