Backspacing/offset. Will this wheel fit?
I found a set of Ultra Type 164 wheels size 16x8, 4 1/4 backspacing, -06 offset and of course 8 on 170 pattern.
Will this backspace and offset fit? I'm planning on puting 315's on them and a 2.5 inch leveling kit. Thanks. |
yes 4 1/4 will fit. the newer trucks have 5.5" backspacing stay away from those rims the tires will rub on the spring if you use them.
Eric |
Thanks Eric. I'm going to buy them tonight. I appreciate the input.
good luck and by the tires rubbing on the 5.5" backspacing wheels that is only on full lock turns...just wanted to clarify that
