Factory rear axle/diff 2002 F350 Diesel 4WD - Ford Powerstroke Diesel Forum
Old 03-08-2013, 07:05 AM
Stuck at work trying to order parts for 2002 F-Series 4WD
<Per fordtechservice.dealerconnection.com using the VIN>
7.3L Diesel Turbo
4 SP Auto 4R100 transmission
4.10 Ratio Axle
Looking through the on-line service manual (Hemi/Motorcraft service) it isn't clear to me which which hub and rear diff I have. Can this info be determined on line or am I stuck until I can slide under the truck tonight.
Old 03-08-2013, 07:49 AM
check the tag on the rear diff...what are you try'n to order?
Old 03-08-2013, 08:17 AM
No access to the truck until tonight
Ya, I know but I can't do that until after the stores close tonight. I was trying to order seals today and find out if I needed the special axle bolt socket so I could pick them up on the way home.
Old 03-08-2013, 08:23 AM
ya, you'll need the special socket, autozoo/kragens..etc, got it for 20 buks...i wanna say, the seals..(inner hub seals) are the same with all our axles..10.5 / 10.25
Sinceur in there, probably get new ebrake pads too
Old 03-08-2013, 11:41 AM
Front axle does not need a special socket. It does however need a special seal driver tool.
