2 small ?'s - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-10-2008, 09:57 AM Thread Starter
00strker's Avatar
2 small ?'s
ok i have a afe stg 2 intake will i see any difference in sound if i do the foil delete???
2. will i see any gains doin the zoodad mod ?
thanks
00strker is offline
post #2 of 9 Old 01-10-2008, 10:10 AM
onecrazyblackredenck's Avatar
zoodad helps lower egts............I didnt notice much difference in the sound when I did my foil delete, I was actually very disappointed but I think I am like the only one on the org that feels that way, heck go for it they are both pretty easy to do........Let us know what you think
03 F250 4wd auto strait pipe quad cab lariat 33x12.50x18
84 K5 blazer CUCV M1008 dana 70 front and rear, detroit lockers front and rear, 45" tractor tires, 6.2 diesel
1978 cj5 built 304 lots and lots of rust
onecrazyblackredenck is offline
post #3 of 9 Old 01-10-2008, 10:13 AM Thread Starter
00strker's Avatar
ok ill try it out wuts the best way 2 get the foil off ?
00strker is offline
post #4 of 9 Old 01-10-2008, 10:14 AM Thread Starter
00strker's Avatar
do u know wher the right ups are on the zooddad and foil-d
00strker is offline
post #5 of 9 Old 01-10-2008, 10:20 AM
silverF250's Avatar
My intake is so loud you can't hear a difference from the foil delete. The foil isn't hard to get off the glue that holds it on is another thing. Zoodad you cut a hole in the header panel in front of the air box, I put a screen in front of the header panel when I got it cut. Some guys make a little scoop that connects the header panel to the air box.
Pat
2000 F250 Carpenter's Union local 2214
LOOKING FOR SIDE JOBS
Mac intake,5" exhaust with6" tip,Zoodad,foil delete, ts chip, WW
96 E350 bad trans mod NO MORE.
silverF250 is offline
post #6 of 9 Old 01-10-2008, 10:22 AM Thread Starter
00strker's Avatar
is a screen needed
00strker is offline
post #7 of 9 Old 01-10-2008, 10:42 AM
silverF250's Avatar
Not necessarily needed I put it in to keep bugs and cigarette butts out of the air box.
Pat
post #8 of 9 Old 01-10-2008, 11:24 AM
I didnt put one in mine......but it does help
post #9 of 9 Old 01-10-2008, 11:59 AM
cj41foley's Avatar
yeah, every now and then I clean out the debris out of my air filter
Jason
2006 F250 2wd 6.0 psd, 8.96 1/8th mile with canned SCT tunes, now running Spartan Hybrid Race tune! AFE Stage 2 PRO DRY S, 4" turbo back str8 pipe in front of rear tire, auto, crew cab short bed, ZOO DAD mod, 5% tint over the factory tint.
Track Times!
Reaction---.674
60 ft-------1.892
594 ft------8.370
1/8th ET---8.965
1/8th MPH--75.63
cj41foley is offline
