Muffler delete pipe - Ford Powerstroke Diesel Forum
Old 03-06-2013, 05:10 PM
Muffler delete pipe
Anyone found any muffler delete flex (read diy- no welding) pipe recently? I have searched the forum and the web but everyone says napa. Checked at 2 local napa stores and oreilly's, no luck... It looks like it needs to be 3.5" i.d. X 30-32" long...
Old 03-07-2013, 03:09 AM
That flex pipe will rust out in less than 6 months. I had the exhaust on my beater Cavalier held together by it... coming from experience here. Just go to a muffler shop and pay them the $20-40 to straight pipe it.
Old 03-07-2013, 03:11 AM
agreed don't use flex pipe
Old 03-07-2013, 02:40 PM
if you are doing a factory muffler delete riffraff sells a factory muffler delete pipe. its 60 bucks.
from the looks of it you just cut the muffler off and clamp it on.
Old 03-07-2013, 08:33 PM
I'll concur. thought I would try to go cheap. got lucky and napa had three feet of 3.5inch id flex sitting there. $42 later ,add $12 for two u clamps and my impatience saved me $15 after shipping maybe. but I got what I wanted. cheap
Old 03-07-2013, 09:45 PM
Muffler delete pipe
Jegs has pipe. Got my 4" and clamps through them. About $50 bucks.
Sent from AutoGuide.com App
Old 03-07-2013, 10:05 PM
You can also get a Walker muffler # 21470 at Summit for under $50. You will need to weld or clamp the connections anyway. This muffler gives you a through design (you can see one end to the other) with less sound when under power. I have this and highly recommend it.
