No crank no start.. HELP
I truck was running fine, turned it off went into the restaurant to go eat. Came back out and no crank no start, tried jumping both batteries and still nothing. I hear the fuel pump come on but no crank.. . help!! Please call 9188517646. In Virginia beach
Did you try tapping the starter? My obs starter went out on me and have very simular effects had go buy a new starter and change them out in a cabelas parking lot.
When I took the old one apart it totally melted inside and was nasty smelling. |
You try jumpin across the starter relay on the passenger side fender??? If it goes bad you get nothin
I will give those a try today when I get off work, had to tow it last night. Cold and raining was soaked to the bone. Hopefully ill get her running soon.
Did you try starting it in neutral? I know on mine I thought the starter went out once, but the bolts on the gear shifter came loose under the dash so it wasn't tripping the sensor.
Bypass worked, changed the starter relay. It cranked right up 3 times and then the same symptoms came back. However bypass jump still worked. After I got it running again I shut it down waited a moment and it cranked back up... Any idea?
