wheels
just curious if 15" wheels will fit on a 1999 f 250 superduty crew cab diesel. i have a set of 44" swampers i would like to install onto this truck. your help is greatly appreciated. Thanks
.....no bud I don't believe so....I think you have at least a 16" to clear the calipers
you wouldnt be able to even grind the calipers down to make them fit hey?
mount up a bare wheel and see what touches, I've had to grind calipers slightly to fit 15" wheels on 1 ton axles in jeeps and buggies.
You can try it.....but are you going to use this truck with the 44s or is it just going to be for show? The reason I ask is because if you do get it to fit and you do use to offroad, you will be likely to get something "stuck" in the wheel between caliper and wheel and damage something.....but let us know if it works!
man if 15" wheels would fit, i'd think more people would go for 'em cause tires are so much cheaper. i sure would. def let us know if you figure somethin out
