HELP HELP MAP FOOLER HELP - Ford Powerstroke Diesel Forum
Old 01-08-2008, 04:50 PM
Exclamation HELP HELP MAP FOOLER HELP
I bought the map fooler i have edge evo 2 and it works great it has a yellow wire that doess not plug into anything but now that i have that on there on my edge it only goes to 12 psi cuz its fooling it how do i fool it and it still reads right boost levels
Old 01-08-2008, 05:04 PM
YEAH BUDDY!
You will have to hook up your boost gauge BEFORE the map fooler. After the fooler it will read a false reading. If your boost gauge is in a "T" fitting, install the fitting between the map fooler and the manifold and you will get the true reading.
Old 01-08-2008, 05:09 PM
my boost is electronic though the edge evolution 2
Old 01-08-2008, 05:11 PM
YEAH BUDDY!
Well since it's reading the "fooled" version the computer is giving the EVO2 your going to have to go with a mechanical boost gauge.
Personally I don't like the digital gauges, I feel they are not as accurate anyway.
Old 01-08-2008, 05:13 PM
i know but i have heard of it working what the hells is the yeller wire for then
Old 01-08-2008, 05:21 PM
YEAH BUDDY!
I don't know, I have an EVO 1. What does it say it's for? When all else fails read the directions.
I can't see how it is going to make your gauge read correct. The basis of the MAP FOOLER is to fool the computer into thinking it's getting lower than actual boost as to not defuel your engine, right? That being the case, your EVO 2 is reading the false readings from the computer AFTER the MAP FOOLER fools the MAP sensor, the MAP sensor sends the false data to the computer, and the computer sends it to your digital gauge.
I don't see a way around it.
Old 01-08-2008, 05:25 PM
International Threat
Ask SEA 71 - he has the commander and it reads the boost #'s from the map sensor - which goes to about 19 IIRC. He also has a mechanical boost gauge mounted on the column that reads the actual boost from before the map sensor.
