Fuel Gauge Problem - Ford Powerstroke Diesel Forum
Old 01-08-2008, 12:42 AM
Fuel Gauge Problem
I recently ran out of fuel whilst the gauge was showing 1/4 full. Pumped the tank out today in preparation to remove it and check the sender and to do the Hutch mod. There was only 5 gallons in the tank but it was showing between 1/4 & 1/2 full.
Can anyone tell me what resistance there should be across the sender unit.
Mine has 75 ohms at empty and about 220 ohms at full, and the transition from empty to full appears to be at a constant rate.
Are there any other checks I can do? I am reluctant to re-fit the tank if there is any doubt about the sender. [The simple thing to do would be to fit a new sender, but parts like that don't come easy down in Aus].
Old 01-08-2008, 01:24 AM
I got no answers for ya, but ur truck looks good. I had to take a double glance at ur a-pillar though b/c it looked like it was on the passenger side, then I noticed the steering wheel and realized that it was on the drivers' side. Just not use to seeing that over here. Anyway, looks good and i'll give you a little
Old 01-08-2008, 11:56 AM
Bump! No takers??
Old 01-08-2008, 12:45 PM
My gas gauge stuck in my Lincoln and in my truck. The people at Ford said it was sulfur build on the sending unit and recommened a gas additive according to the TSB put out by Ford.
Old 01-09-2008, 04:16 AM
my 99 was doing the same thing I put cheveron add. in it and ran a full tank and no more porblems I got mine at O railey auto parts
