New truck
Hey guys,
I have been reading a little on here for several months, but I just bought a 99 350. I'm only using it for work, but I would love to hear about some simple or cheap mods to make it a longer lasting truck with moderate power. Also, any info on things to look out for that may be going bad would be awesome. 2wd, 236k miles. 4 door with flatbed. No engine mods, has a big air filter. |
Anything? Is straight piping it a good enough substitute to a 4 inch pipe? I want to keep egt's down. Also, what gauges are recommended for the 6 speed. EGT, boost, ??
New truck
Egt boost and oil pressure, I straight pipe dose help lower egt but not as well as a 4" system.
Sent from AutoGuide.com App |
That sounds good. I dont really plan to do any power upgrades since it is a work truck, so I don't think I should have a problem with egts in the first place, but I will tow heavy occasionally.
What brand of gauges are popular and reliable? |
ISSPRO EV2.
I would get EGT, boost and fuel pressure. Oil pressure isn't a bad idea though. |
Which is more likely to cause problems? Poor oil pressure or poor fuel pressure?
Anyone know where I can get the following?
Parking brake cable and release Cup holder Shifter - the shifter will lift off from the bottom part, I guess the nut and rubber broke. Interior lights won't come on when the doors open, stealership? |
ill get you part numbers for the other parts |
I have used AutoMeter gauges with good luck. Even with a work truck, a good tuner can help. I have DP Tuners on 2 of my trucks, one of which is a 6sp. I've been running one on my F350 dually for 5 years, have an 80 hp economy tune I use 95% of the time, which picked up 1-2 MPG and alot of driveable power. The Deceleration tune is great for towing and even empty, kick it in, and the EBPV kicks in like a jake brake to help maximize the motors help slowing you down. Yes, you can switch tunes on-the-fly, while driving even. It's nearly instant. Both trucks have these tunes: Stock, 1200 rpm hi idle, 40 0r 60 hp tow tune, deceleration tune, 80hp econo, and the red F250 has a 120 race tune. Once you run a good tuned truck, you'll never go back... You said you already have a big air filter... Straight pipe the stock exhaust... Gauges: Boost and EGT for sure... Good tunes, not canned stuff like banks, edge, etc. Go for a DP Tuner, or others like the TS 6 position chips with tunes on them from people like Tony Wildmand, Bill at PHP, swamps, etc. |
