Power Steering / Brake Issues - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-04-2013, 03:07 AM Thread Starter
ammojeep's Avatar
OK, first off... '02 F-350 Dually 7.3l
Problem #1: Brakes are very stiff and having to stand on them.
Problem #2: Power steering not working, feels like I am driving an old B model Mack!
I did see that Ford has lines running from the PS pump to the MC. So I am assuming these problems are affected by the same issue.
I have full levels on both reservoirs. No abnormal noise from PS pump (i know Fords have distinct, annoying whine).
Any ideas?
I did notice when I finally got home, there was some PS fluid that had puked out of the reservoir. But the level is still within range.
A little past history, for the last few months, my steering has been not really loose, but Very easy to turn. As in, a flick of the finger can spin the wheel almost a full turn with too much ease. Kinda hard to explain, but I hope you get the point.
Any and all help is appreciated as I need my truck this weekend.
Thanks!
ammojeep is offline
post #2 of 3 Old 03-04-2013, 04:17 AM
Jrz13's Avatar
sounds like your priority valve might be stuck
Forged Rods
ARP Head & Main Studs
Port, Polish, 3 way valve job
Beans 160cc Single Shot Injectors
DI Regulated Return/Oil X Over
DieselSite Coolant Filter
TS 6 position (Beans Tunes)
AFE stage 2 dry
Labonte Stage 3 Methanol Injection
Banks wheels, exhaust housing, wastegate, Intercooler
5in Turbo back Exhaust
Custom Built Trans w/ Billet Shafts
Mag-Hytec Trans Pan/Diff Covers
6.0 Trans Cooler
SnowDogg EX90 plow
Jrz13 is offline
post #3 of 3 Old 03-04-2013, 09:41 AM Thread Starter
ammojeep's Avatar
And that is in with the MC?
ammojeep is offline
