Track bars on non lifted truck? - Ford Powerstroke Diesel Forum
Old 03-03-2013, 03:29 PM
Will track bars fit fine on a non lifted truck?
Old 03-03-2013, 03:40 PM
one up off road makes a kit. about $1000 though.
Old 03-03-2013, 05:15 PM
iv already got trac bars im just wondering if it will make a difference if the truck is lifted or not?
Old 03-03-2013, 05:23 PM
Re: Track bars on non lifted truck?
Depends on how much it is lifted/leveled if you need aftermarket track bar. All solid front axle ford and dodge have them OEM since Dana is the manufacturer. If its lifted a lot then an adjustable is needed.
Old 03-03-2013, 05:38 PM
i think he is asking about traction bars(ladder bars) instead of a trac bar. but i might be wrong.
OP i'm not sure but i don't see why not
Old 03-03-2013, 05:45 PM
true i mean ladder bars they are just called different things all over the country.
Old 03-03-2013, 05:47 PM
i know what you mean. i call they traction bars myself.
Old 03-03-2013, 05:48 PM
LOL. Well all three are much different from each other.
To the OP.
Track bar is mounted parallel to the front axle to prevent bump steer
Traction bars usually attach to bottom of leaf springs and help with axle wrap by a rubber stop that hits close to the front shackle of the rear leaf spring.
Ladder bars also are for axle wrap and pretty much eliminate it, by adding brackets to the axle and the frame for a ridgid/rough ride.
Old 03-03-2013, 05:50 PM
To the OP.
thanks for that info man ill be sure to remember it for the next time
now do you think ill have any problems installing ladder bars on a non lifted truck?
Old 03-03-2013, 05:51 PM
Lol. Just look the names up in Summit Racing or Jegs and you will see the difference.
