fuel leak - Ford Powerstroke Diesel Forum
Old 03-03-2013, 09:48 AM
fuel leak
I have a 2001 ford f250 4x4 crew cab i bought in texas, i had no leaks of any sort in texas drove to pittsburgh pa it around 20 dgrees truck sat pluged in for a day or so i went to move it ,it started on the second try blew some white smoke, not much but i noticed fuel leaking comeing down around the front of transmission and bell housing what happen?
Old 03-03-2013, 10:22 AM
Here is a fuel diagram on the motor, might help you look at some the lines
Old 03-03-2013, 10:39 AM
probably fuel bowl drain. pretty common. check out guzzles site, it will show you have to rebuild
Old 03-03-2013, 10:46 AM
fuel leak
Yea just order a fuel bowl o ring rebuild kit and get it over with you could just do the drain valve but it just quicker to do all o them and be done. Def check out guzzles page great directions
Sent from AutoGuide.com App
Old 03-03-2013, 02:44 PM
inspect the p/s fuel line, running thru the "P" clamp.
