First Timer Here W/ Questions !!!!!! - Ford Powerstroke Diesel Forum
Old 01-06-2008, 02:16 AM
Hey Guys,
Just got my first dulley 2000 7.3 f-350 lariat crew cab,
was woundering. . . . . . . .
1. I want to simply take a Saw-Zaw or Saw and cutt the muffler and take it off and throw it away, im not going to put a new pipe or anything JUST CUT OFF and throw away, that way it will be loud, RIGHT. . . . . ???
2. Will It Hurt My Motor, or will it hurt ANYTHING.
3. I Want Smoke, Big Black THICK Smoke, How Can I Get That.
Sorry But Im A BRAND NEW Member This Diesel Stuff PLEASE HELP.
THANKS ALL
Old 01-06-2008, 02:43 AM
Originally Posted by Ford7point3TurboDiesel View Post
Hey Guys,
THANKS ALL
I would at least run the end of the pipe out in front of the back tire....if it ends under the cab you will get exhaust drone..I would also add a cold air intake like the Napa 6637 filter for around 50 bucks..it will breath better and you will here the turbo whistle a lot more...after that..add some gauges..pyro for exhaust temps..boost gauge,, and if you have an auto Trans...you will want a Trans temp gauge..after you do that....add a chip and watch the smoke roll...
Old 01-06-2008, 03:45 AM
Just make sure to get the gauges before a chip, and I would get a custom chip such as DP tuner or Tony Wildman.
Old 01-06-2008, 05:55 AM
I would definitely run the exhaust out the side of the truck. The soot will stick to the underside of your truck and make a big mess.
Old 01-06-2008, 03:47 PM
i did it to my truck and its louder, i think.... if you go through a tunnel its loud i ran it out just infront of the rear tire and it is fine. if you really wanna look and sound cool put on some sacks
Old 01-06-2008, 03:59 PM
Welcome to the Org.... its not gonna hurt the motor like everyone says.... as far as smoke... youll need a tune for that... my suggestions is TonyWildman chip with gauges...
Old 01-06-2008, 04:09 PM
Ole White
